19-12-2015, 10:28 AM
ph3 estate 1999/2000, the rear tailgate seems not to want to drain water, and when its opened, water runs out, under the inner black plastic panel and then into the rear of the car.
What holds on the lower trim panel, the one on the outside running from left to right please. An exploded parts view would be great.
Any common fault leaks on the tailgate that lets in water into the tail gate?
Maybe the rear washer pipe is leaking but it doesn't look/smell as if it has screen wash in the water.
