16-01-2015, 08:54 PM
So im in need of new injectors, found a pic online with what cars i can get them from,
Does it matter what year car?
hdi injectors
16-01-2015, 10:29 PM
No, the year doesn't matter, although newer is more likely to be lower mileage, as long as you have a full set of the right part number.
044s also seem to be more prone to ticking than 076s.
16-01-2015, 10:36 PM
https://www.check-mot.service.gov.uk/ GTI6 Info Don’t drive faster than your guardian angel can fly.
17-01-2015, 02:45 PM
So go for 076's? Il try and find some cheap as mine are getting worse and worse.
Cully i found it on google and stole it :-D
20-01-2015, 04:50 PM
(This post was last modified: 20-01-2015, 04:51 PM by tysonbully2k12.)
So i found 2 sets
1st set from 307. Look completly different 2nd set from 406, there 062's. 2nd set
Some 307s came in siemens varient
20-01-2015, 04:56 PM
Yep, as above, the top set are Siemens, easily identified by the leak off pipe being on the side rather than top.
20-01-2015, 05:02 PM
Thought they looked weird,
Might try and get the 406 ones cheap Only thing is i dont know what mileage and 406s are usually high milage
