	Threads: 55
Car Model/Spec: D turbo 1.9
		Hi all so I hit a problem with my d turbo. I fitted the 2.1 all gd and now got to the start up point and stopped. It turns over fine and wants to fire I asked a friend what he thought about it and he said are the lines on wright and confused me are the xud11 and xud9 both the same when comes to fuel lines or not it's got a Bosch pump on and plumped the same as 1.9 any ideas thanks
Or do I advance or retard pump un shore where to go with it now
	Threads: 143
10
Car Model/Spec: Ph3 XUD
	Given 8 thank(s) in 8 post(s)
		Got 12v to the stop solenoid?
	Threads: 55
		Yea that's all connected but I will double check it's defo get a 12v feed tomoz
		Got fuel at all the injectors?
	Threads: 55
		Haven't checked that but I will do
	Threads: 55
		Sorted it now all running gd was a damaged wire to stop solinoid
		Awesome...std tune/turbo??
	Threads: 55
		11mm Bosch/ fmic / td04l ATM just after a paddle clutch now
	Threads: 55
		Yea I probably will do soon thanks
