	Threads: 1
		Need help, I was driving my car to work and all my dash lights flicker and all my clocks go funny, door locks goes off and the radio goes off as well when I am changing gear, but when not changing gear on a straight road its OK. Taken radio out but still does the same. Check the main fuses there ok and the battery is covered properly. I'm stomped ????
	Threads: 11
		try cleaning the all earth leads from the battery to the engine and the one to the body these are known to corrode and break a quick test maybe use a jump lead from the battery negative to a earth on the engine block see if it still does it.
	Threads: 115
26
Car Model/Spec: 306
		As said check the earth's from battery to engine and battery to body I have had the exact same issue
	Threads: 3
		Check the alternator. I had all sorts of electrical problems, airbag lights, etc on a Xantia due to the low voltage coming from the alternator. I used a multimeter and seen the voltage was really low.
