306 hdi balljoints
Hi all,
im going to be getting two new balljoints for my ph3 2.0hdi lx model, does anyone know if it will be 16 or 18mm one's fitted as I believe there are two types?
cheers
steve
Should be 18mm on the HDi....but best to check in case hubs been changed. Also make sure theyre power steering BJs.
ok will do, cheers Smile
Mine were 18's found out after accidents buying a 16mm ball joint
