	Threads: 208
60
	Given 5 thank(s) in 5 post(s)
		Not sure but i always put tight coil down??
![[Image: DSC_0190-Copy_zpsf093f84d.jpg]](http://i1038.photobucket.com/albums/a468/167gti8/DSC_0190-Copy_zpsf093f84d.jpg) Member of 99% warning or your nothing club!
	Threads: 183
20
	Given 8 thank(s) in 8 post(s)
		The left side is correct iirc. The large coil sits in the bottom of the strut and the small one to the strut top.
![[Image: 6b0c7309-5184-463c-9f73-2a7b96601418_zpsfdf041fe.jpg]](http://i512.photobucket.com/albums/t326/kent16_2008/6b0c7309-5184-463c-9f73-2a7b96601418_zpsfdf041fe.jpg)
	Threads: 42
28
		makes no difference whatsoever.
	Threads: 141
35
		306 springs aren't tapered on one end, just flat with the same size half coil on each end, as long as they're seated in the cups correctly its fine
