23-12-2013, 11:36 AM
that would be your gearbox
Oil change
23-12-2013, 01:22 PM
(23-12-2013, 11:36 AM)Piggy Wrote: that would be your gearbox what he said . . . . . ermmm is this your first oil change by any chance fella? . . .
23-12-2013, 01:34 PM
sorry, its not funny.
Its freaking hilarious ![]() oh and on a serious note...DO NOT DRIVE IT AN INCH BEFORE REFILLING THE GEARBOX! Wishes for more power...
23-12-2013, 01:43 PM
Make sure you fill the gearbox with gear oil of the proper grade, 75w90 rings a bell but double check.
The gearbox filler is a black plastic bolt with a white breather in the top of the gearbox almost directly above the plug you drained the oil from. You'll need to remove the air intake pipe to get at it properly. The engine oil sump plug is directly under the middle of the engine but might be at the back very low down rather than underneath.
23-12-2013, 04:15 PM
23-12-2013, 04:37 PM
Yeah thats the gearbox...
24-12-2013, 09:04 AM
Oh sh*t. That'll teach me for doin it hungover.
I have already driven it. Hope I've not knackered it.
I feel like such an idiot!
Just picked up some gearbox oil. Luckily I've captured all the gearbox oil so I know how much put back in. Just to be clear, it's filled from the top under the air throttle intake? Then I'll do my oil change (from the engine) and hope I've done no lasting damage
24-12-2013, 10:58 AM
The gearboxes are pretty hardy.
The filler plug is on top of the gearbox buried under some air pipes between the battery and thermostat housing. Its usually a black plastic nut (21/22mm rings a bell) with a white nipple on top of the nut that is the breather. The gearbox takes 2l of oil so just pour in 2 bottles. If you were closer I'd offer to help you with it.
24-12-2013, 11:28 AM
Cheers guys. I'm still a little red faced here
![]() Luckily I don't need the car for a few days so gonna sort it after Christmas. Should be easy to sort now I know where I went wrong. I'll be sure to get in touch if I need your help tho.
24-12-2013, 09:38 PM
Isnt there a level plug on the side of the box 19mm? You can fill through there or from the black plastic nut on the top 17mm i think.
24-12-2013, 09:53 PM
24-12-2013, 10:06 PM
Easiest to fill from top...use side level plug just for level...right pig to fill it from there
Yeah but I wouldn't worry about the level plug if you know you've drained it as it takes 2l and gear oil is sold in 1l bottles unless your a garage using 5l+ bottles.
24-12-2013, 10:39 PM
I used to fill from a big drum at the garage with a little pump
25-12-2013, 06:18 PM
I get it every now and again with the stubborn filters. Mostly Renaults. If its realy seized iv had to chizle at the base of filter on a few occasions to get it to turn. At least you'v now got fresh gearbox oil too lol
31-12-2013, 01:40 PM
Sorted this saga out this morning.
2 litres of fresh gearbox oil.... Done! Fresh oil change (Shell 5w40 fully synthetic)... Done! Question tho... How accurate is the oil level sensor under the speedo? It's reading max but the dipstick is halfway between min and max?? Gonna leave it til tomorrow now and check the levels again. Thanks for everyone's help too
31-12-2013, 01:48 PM
Always go by the dipstick reading.
