	Threads: 374
38 Location: Isle of Wight
 Car Model/Spec: GTI 6
 Thanks: 8Given 16 thank(s) in 14 post(s)
		Had this little niggle for a while.
I'll try and describe this the best i can; i believe Poodle also experienced this whilst he was passenger the other week. Both fairly stumped.
Firstly, it doesn't affect the driving too much, but does make a kind of vibration noise.
This issue only really happens (id assume) at around 2.5k/2.7krpm - 4krpm or so.
I'll be acceleratiing and suddenly a heavy 'grrrrrrrrrrrrrr' , not really an agressive sound, but a lower tone to the whole engine noise.
In combination with the sound, comes an overly sensitive throttle, i can literally blip the pedal and the car will jump. When "off" the issue, the car obviously won't jump; similar to a petrol at high rpm "jump" if that makes sense.
The issue doen't happen at speed; it's rpm related, so i can be sat still revving and still hear the low noise.
I hope this has been explained the best as possible, if anyone has any ideas, please chuck it in. The car will be at FCS, so if anyone wants to listen and try and diagnose, be my guest!
Just a little curious i guess; it's done it since the car's been running. A good 4/5 weeks now
I can try get a video if anyone would like.
thanks!
54 Location: Cotswolds
       Thanks: 22Given 68 thank(s) in 68 post(s)
		sounds like a dodgy governor?!
	Threads: 374
		16-07-2013, 12:04 PM
(This post was last modified: 16-07-2013, 12:04 PM by ginge191.)
		Could be; the pump hasn't been touched internally...?
	Threads: 202
58 Location: Eastleigh
 Thanks: 2Given 29 thank(s) in 28 post(s)
		Does it coal more if you put your foot down when it's being all sensitive?
	Threads: 374
		 (16-07-2013, 12:05 PM)Jonny81191 Wrote:  Does it coal more if you put your foot down when it's being all sensitive?
nope not particularly, it coals about the same amount until on full chat; then clears up, as per with an derv tune
	Threads: 374
		hmm anyone else have any ideas, anything else to check out?
	Threads: 90
54 Location: Cornwall
         Thanks: 0Given 20 thank(s) in 18 post(s)
		Sure its not just the LDA dropping with boost..
| Dyno Power Runs & Steady State Facilities Available, Just Ask Anytime || #DervMafia |
	Threads: 33
2 Location: Shrewsbury
 Car Model/Spec: 306 D-turbo/306 Rallye
		I know exactly what you mean, mine does it as well, i believe it to be something to do with gov/lda, can show you at fcs if you like
Blaze '6 and Blaze D-turbo!
	Threads: 374
		16-07-2013, 03:50 PM
(This post was last modified: 16-07-2013, 03:51 PM by ginge191.)
		 (16-07-2013, 03:44 PM)darrenjlobb Wrote:  Sure its not just the LDA dropping with boost..
I don't think so; i've never had this with any DT before.
If i remove the pin and attempt rev, would this rule the problem in/out?
  (16-07-2013, 03:49 PM)Mitch Wrote:  I know exactly what you mean, mine does it as well, i believe it to be something to do with gov/lda, can show you at fcs if you like
interesting; how long has your's done this now?
any pump mods?
	Threads: 90
		Dont take pin out, wind starwheel up a bit, and see if it has any effect.
	Threads: 33
		16-07-2013, 03:55 PM
(This post was last modified: 16-07-2013, 04:00 PM by Mitch.)
		 (16-07-2013, 03:50 PM)ginge191 Wrote:   (16-07-2013, 03:44 PM)darrenjlobb Wrote:  Sure its not just the LDA dropping with boost.. I don't think so; i've never had this with any DT before.
  (16-07-2013, 03:49 PM)Mitch Wrote:  I know exactly what you mean, mine does it as well, i believe it to be something to do with gov/lda, can show you at fcs if you like  interesting; how long has your's done this now?
 any pump mods?
Ever since the bosch has been on, around a year, only a ground lda, unsure about gov as it came of a 'tuned' xud previously, but i wouldnt of said anything has been done gov mod wise.. Mine only seems to happen between 3.5k and 4.5k though.
	Threads: 374
		 (16-07-2013, 03:52 PM)darrenjlobb Wrote:  Dont take pin out, wind starwheel up a bit, and see if it has any effect.
I'll have a tug tomorrow when i'm under the bonnet with swaughan
	Threads: 33
Going to go and try this now, will let you know results
		I'll put money on LDA... Mine does this majorly, hence why I removed the spring...
		 (16-07-2013, 06:09 PM)Ruan Wrote:  I'll put money on LDA... Mine does this majorly, hence why I removed the spring...
surely that means it stays down all the time?!
	Threads: 90
		Yeah, just turns it into a NAD pump, ideal really, right foot > LDA    all day long
		LDA causes all sorts of weird timing issues... That's what causes the typical XUD intermittent power... What people always do is wind the star wheel up so it takes a lot to drop it on boost, wind out the smokescrew so there's no fuel off boost, so you then jam your foot down, you've got loads of max fuel so you've got shit loads of tension on the governor against the LDA pin...
 So you've got no fuel to drop it,  it's sprung so that it can't drop easily and is being pressed so hard sideways from the governor from the pedal requesting shit loads of fuel... Its a wonder it ever drops!!!!
 This is the precise reason VEs are a bloody nightmare!
		so basically an improved progressive replacement spring would be better?
 Or is foot control the way forward!?
		Doesn't solve the other issue of the governor pressure. That's what'll almost always PROPERLY jam it...
 That's why if you "feed" the throttle in slowly, it'll end up pulling better, mash your foot into it, it'll probably jam out and not work right...
 But if you're feeding it in anyway, why not just do it manually anyway, then there's no chance of jamming it... Just more chance of a complete engine bog with way too much fuel, but you quickly get used to dipping the clutch and slipping it a bit to clear it and bring it on boost quicker anyway.
	Threads: 374
		So slight update; I rotated the star wheel anticlockwise/up about 8 clicks.
 It hasn't made a huge difference; a slight difference if not a placebo affect on my ears. Bits it's still there.
 Anything else i could try?
	Threads: 33
		id try winding it up some more, wound mine 2 whole turns and its made it slightly better id say
	Threads: 374
		But what affect would this have on the LDA?
	Threads: 41
12 Location: Midlands
 Car Model/Spec: Dtractor
 Thanks: 0Given 6 thank(s) in 6 post(s)
		+1 for the spring removal    how mine currently is. Not only do I had ecus not letting me have the fuel I request but got sick of ve's not responding either!
	Threads: 374
		Remove the spring all together and regulate fuel via throttle an right for control?
