	Threads: 55
Car Model/Spec: D turbo 1.9
		Can anyone help me my hdi cut out on me a few days ago and would not start again so took to a garage and turned out it was the fuel pump in tank so fitted another one and it was fine drove two miles down the road and cut out again so gone bck to the pump and it is coming on and u can hear it but nothing so took the pipes off it and put a peace of pipe out of the car into a bucket and turned the key on and it comes on but not pumping any diesel any one got any ideas maybe blocked not shore thanks chris
	Threads: 18
		Sounds daft but there enough fuel in the tank? Also make sure the arrow on the pump is facing the c pillar; just means the float for the fuel gauge doesnt read out i.e. It says you have a quarter tank when really its nearly empty, if that makes sense.
Otherwise it could be a faulty pump? But definately sounds like your at the source of the problem bud
		03-05-2013, 07:28 PM
(This post was last modified: 03-05-2013, 07:29 PM by Poodle.)
		Did the garage do the swap? If so, i'd be inclined to take it back to them - they haven't fixed the problem you've paid them to do.
	Threads: 55
		No the garage diagnosed the problem and I did it my self as they where asking an arm and a leg to it
		Ah bugger, ok. In which case have a look at my thread in the guide section, think it's called "if your hdi cuts out or feels under powered". I'd start with the brown relay if i was you.
	Threads: 55
		No I took them both off at tested the big pipe with the arrow pointing out wards and ok ill give ur thread a read thanks
	Threads: 55
		Had car running fine but cuts out without and warning on tick over and cuts out over 3000rpm but I can't start it I can turn it over for 10 mins on the jump starter before it starts any ideas before I kill the starter thanks I have fitted new glow plugs also
	Threads: 50
Car Model/Spec: 306 HDI Dturbo
		Might not be related but recently my hdi wouldn't - start turned out it was the plug on the fuel pressure regulator was slightly loose! Clipping it firmly back into position did the trick
		Haha nice easy fix! Always worth checking simple things like that before getting stuck in, might add a note to my guide actually...
		Haha yeah, i've found nothing is even close pp2k when it comes to fault finding on the hdi. If anyone ever has a non-starting or cutting out problem with their hdi, its probably the best thing to buy first, unless you've already got a verus or similar.
