Threads: 162
21
What penetrating oil do you guys use?
I've used plus gas but I don't find it too good and I've heard good things about Q10. Has anyone here used this stuff?
Threads: 289
92
Car Model/Spec: Phase 17 R26
Inb4Samass/giggidy
I use 3-in-1
Threads: 541
124
Threads: 162
21
03-03-2013, 09:50 PM
(This post was last modified: 03-03-2013, 09:51 PM by DeeTurbo.)
Is 3-in-1 not a little too thick to work as a penetrating fluid?
Threads: 289
92
There are a few different ones though, the orange one is penetrating spray.
http://www.halfords.com/webapp/wcs/store...yId_255223
Threads: 55
17
Car Model/Spec: 406 V6
Plusgas.
Threads: 78
49
As the thread that was just up about this, Plus Gas. Can't fault it.
Threads: 130
82
Car Model/Spec: 106 GO-NAD
Yeah, another plus gas vote, bit, the 3 in 1 stuff is pretty good, but plus gas is better I find
Threads: 78
49
If it's something you know is going to be trouble, soak it in advance to give it a chance to work
Threads: 162
21
03-03-2013, 10:04 PM
(This post was last modified: 03-03-2013, 10:05 PM by DeeTurbo.)
(03-03-2013, 09:54 PM)Scott Wrote: There are a few different ones though, the orange one is penetrating spray.
Oops thought you meant the multi purpose oil.
(03-03-2013, 10:04 PM)Curt Wrote: If it's something you know is going to be trouble, soak it in advance to give it a chance to work
Very true, planning ahead and all that.
Threads: 202
58
I normally make the offending item hot with a blowtorch. Then spray it with whatever I have lying around, usually wd40 or gt85 while it's still hot. Seems to do the trick.
Threads: 208
60
Given 5 thank(s) in 5 post(s)
Plus gas & 3in1 (orange can)
Threads: 151
14
Car Model/Spec: 306 D-turbo
Elbow grease works well for me
Team Doesn't own a 306
Threads: 186
38
Car Model/Spec: MG ZR VVC
a bit of spit gets things moving for me
Threads: 94
7
Car Model/Spec: 205 coming soon
KY jelly does the trick when I'm penetrating
Official Team Go-NAD fan club
Threads: 29
39
Car Model/Spec: Ph 2.5 Nile Blue GTi6
I heard using sand helps?
I mean those VTEC boys can't be wrong.
Double TT
half price of wd40...twice as good
Threads: 169
91
Astraglide
/thread
