06-03-2017, 10:32 PM
Hi All,
Im selling my Fletcher Arrowsport 155 as ive now upgraded to a bigger boat. Its got an evinrude 70hp 3cylinder 2 stroke on the back which is more than enough for this boat. I replaced the floor with proper marine ply which was fibreglassed in, recarpeted and fitted a 306 interior to it when I got it 5 years ago and Its had two more 306 interiors since then. Actually better than the original interior as its more comfortable and fully adjustable! Transom is sound. Its got some sony waterproof speakers fitted upfront with a fusion marine radio. Comes with two 25L fuel tanks which is more than enough for a day afloat. Has a ski pole fitted.
In order to get this to a saleable state its had a full service, gear lube, sparks, grease. The trailer has also had new 750kg suspension units, bearings, wheels and winch.
bad bits... engine needs easy start to start from cold. Trailer is roadworthy but needs several rollers and mounts replacing.
It puts out a moderate wake and is good enough to get some air. Light enough to tow without a towing licence. Can be seen running.
Build thread here... http://www.306oc.co.uk/forum/showthread.php?tid=2803
Located in Felixstowe and now listed on ebay with more details.
http://www.ebay.co.uk/itm/-/232288629066?
![[Image: 487243_4317430415117_1922593443_n_zps2uppoej4.jpg]](http://i1184.photobucket.com/albums/z327/srowell3/487243_4317430415117_1922593443_n_zps2uppoej4.jpg)
![[Image: 181887_10200126548627619_1738659253_n_zpsk6e529sd.jpg]](http://i1184.photobucket.com/albums/z327/srowell3/181887_10200126548627619_1738659253_n_zpsk6e529sd.jpg)
![[Image: 736039_10200207377248284_265150836_o_zps3vfbkbyh.jpg]](http://i1184.photobucket.com/albums/z327/srowell3/736039_10200207377248284_265150836_o_zps3vfbkbyh.jpg)
