Wiggling Gti
Noticed recently the Gti is starting to wiggle.
It feels like there's a bit more play in the steering before getting any result and when going over bumps/hard corners it feels like the backend is coming around
It's not just me being over enthusiastic or slippery roads as its getting worse and doing it in places it never been an issue before.
I've not had a proper chance to look at it yet but wanted some advice about where to start.
And no, unfortunately haven't done a RWD conversion
Beam mounts?
As above, sounds like classic beam mount symptoms.
Best way to test and best replacements then boys?
(27-01-2017, 10:10 PM)rocker8742 Wrote: Best way to test and best replacements then boys?
Has yours not got solid beam mounts?
I don't think it has ... Will have to double check now lol
if it has solid mounts id go for shit rear tyres on a damp road or an imbalance of the brakes or even using the brakes into the corner
GTI6 Info
(28-01-2017, 12:10 PM)cully Wrote: if it has solid mounts id go for shit rear tyres on a damp road or an imbalance of the brakes or even using the brakes into the corner
It's weird though it's not so much on the brakes more when you plant it on the exit it almost feels like the rear left squats down and lifts the front up
check the rear dampers are ok, and that the beam isn't worn out.
I'd hope it's not the beam was a Steffens rebuild within the last 2 years
Sent from my iPad using Tapatalk
As said check your mounts especially the fronts they get over looked. Im not sure if chris fitted new when i built it for him.
90' 205 gti6 supercharged
05' Evo 9 IX GT
Team eaton.
Ill pop it in the air this week/weekend and see where we're at [emoji1303]
Had a nose under last weekend, definitely solid mounts and I've got yet another goosed rear shock, that's now 2 on the same side in 7 months
What brand are they?
They're Koni adjustables
Koni yellows? Mine have been great and still look and feel as new, including after having been on sprints, prescott etc.
Strange!
62k Diablo Phase 1 Gti-6:
Project Thread
Is a bit weird, although don't know what previous life they've had.
need to see how much Koni charge for a refurb and maybe set them a little stiffer
Out of interest how hard are yours set?
