Speedo intermittent
Project cheap estate...
Other issue...
Speedo regularly, sometimes repeatedly, drops to zero then pops back up
Any ideas? New speedo sensor?!
can be three things speedo sensor wiring dash. never seen a dash go down. check the big loom plug on the wing for corrosion. if thats ok bang a speedo sensor in it. Smile
It will be the vss had it happen to my old hdi before, also get a loss of power when it does it.
(28-06-2016, 08:13 PM)Strikeforce Wrote: It will be the vss had it happen to my old hdi before, also get a loss of power when it does it.
The vss??
vehicle speed sensor
yep VSS definitely, one of the easiest jobs ever
306 hdi 3dr moonstone
205 gti6 bare shell rebuild
m3 evolution coupe weekend hero
bmw x3 xdrive35d f25 313bhp nutter
Yep agreed with the above, VSS Starting to show signs of failure. About £30 for a replacement.
Ok thanks chaps
He could've bought something alittlemoreexpensive after all the fixes this needed. Tongue
But yeah its the speedo sensor, another common fault.
Now dubbed
#projectallthecommonfaults
