Anyone running Pug 307 266mm Brakes?
Well if you are, snap these Brembo Max Discs up quickly, remember these will NOT fit standard 266mm Peugeot 306 Brakes, only calipers from the 307 or if you have a 307 with 266mm front brakes! (I know, bit of a long shot but someone gets a bargain hopefully)
http://www.amazon.co.uk/Brembo-09-8695-7...-0&sr=1-10
Look on the right and select the "USED" discs, while it says it is used, most likely it's just the box that is damaged. I bought a pair of 283mm and the discs were brand new, the box was only slightly damaged in the corner!
P.s, you can check your cars fitment here:
http://www.bremboaftermarket.com/En/Car_...Mode=Model
Nice find, they deffo no good for 306 266's then?
Definitely no good, the part numbers don't match up Sad
Stiffer calipers and 10mm more disc offset on the 307's, that's what I ran on mine.
