Threads: 448
51
so it seems the rallye may be down on power.
Where do I even start, engine is on 115k with 6 monthly services.
Has a wanky air filter apart from that engine is standard really
Where do I begin looking to gain power back? How does it lose power from when it left factory?
Threads: 15
Car Model/Spec: XSi
They don't really. When you say wanky air filter?
Could be a number of things from sticking brake to servicing to fuel filter to throttle cable not tight
P1 XSi track car
2.4 LWB T4
Get pp2k...lets see what that and the lambda say
Threads: 448
51
I'll have to wait till fcs for and ask someone to bring it to find out.
Wanky air filter is Litterally a cone on the end of the snorkel
I'm pretty sure timing is spot on, with this engine I'm pretty sure if the timing is wrong it will tap it's tits off
What would a compression test prove? Genuine question. Also how do I go about it?
Matt one simple thing to try which may point you strongly in the right direction (but not a guarantee). Unplug the lambda sensor and see how it drives then. If it picks up slightly and feels smoother, id put money on a bad lambda.
Threads: 58
Car Model/Spec: Loads
Compression tests do little, you want a leak down test done as this tells you where if any faults are with leakage
Threads: 448
51
I'll give the lambda a disconnect tomorrow on my way to work and see how that feels.
And I'll look at getting someone to do a compression test, Cba with going out to buy all the gear someone will have a tester.
And miles how do I go about that? And what will it show me?
Threads: 202
58
If you're able to get to me one Saturday morning I can have a look at work, just give me a call.
Threads: 15
Car Model/Spec: XSi
I'd check one wheel isn't roasting hot after a drive. Bet you've got a sticking caliper rather than an engine problem
P1 XSi track car
2.4 LWB T4
