	Threads: 12
Car Model/Spec: Ph-3 Diablo Gti-6
		Hey, guys
sound does not appear on the music system, power on but no sound.
Original radio and radio nakamichi also have the same problem.
How Does the information can I solve this ?
	Threads: 85
8
Car Model/Spec: E90 330i
		Was it working before and not now?
Or did you buy the car like that?
	Threads: 20
Car Model/Spec: 306 hdi estate
	Given 3 thank(s) in 3 post(s)
		I had a similar problem to you, i found the problem to be a few broken wires in the tailgate, where the wires come from the body to the boot
	Threads: 12
		sometimes the sound comes up and goes, then its all gone. If there is a problem with just one speakers wiring, does it affect the hole connection ? Another question, the speakers runs with the head units energy or they have own fuze or something ?
	Threads: 15
Car Model/Spec: XSi
		They just use the headunit signal. Check door loom wiring through the rubber
Could be the headunit internal amp has died
P1 XSi track car
2.4 LWB T4
	Threads: 12
		I have found the problem maybe someone need this
thats because the speakers cable touches to the door (metal) and makes short circuit
