Pesky rock
[Image: 306-1.jpg]
On my way to work this morning on the A602 just joining the A10 Dual Carriageway and halfway down the slip-road I come across a couple of big-ass rocks. positioning the car above the biggest one and braking hard I collided with another one, instantly wrecking my front passenger wheel and tyre Sad
The best was yet to come; fitting the spare wheel at the end of the slip-road with no hard shoulder. My car-sharing colleague put on a Hi-vis and took the little triangle 50 yards up the road. wheel changed in 6-7 minutes and drove straight to the garage - it was pulling badly to the left on the way Sad
So if anyone has a spare Cyclone and is local to Hertfordshire please let me know!!
[Image: Sig500x130.png]
Ah mann not good.
Could be a lot worse, we had a customers 911 in, 168 miles on the clock, floor pan totally destroyed by a brick someone left in the road!
Matt-Rallye Wrote:Norledge for prime minister.
Poodle Wrote:I reckon Norledge has got it on the head mind.
Matt-Rallye Wrote:Norledge gets my vote tbh.
Damn, bet that sorta stuff falls off overloaded skips all the time.
Yep, massive it was, about the size of two house bricks.
Knew instantly the tyre was toast, was amazed how the wheel now has a big ol' dent in it.
Was quite impressed with how quick I got it all swapped over bearing in mind the conditions and that the spare wheel cradle is f*cked!! And yes, I did initially drive off with the cradle dragging along the ground!
I hit debris too. Costing me £62 for a new michelin ps3 fitted.
That's not bad. I have Michelin PS2's on the front, so I'm not sure I'll even be able to find another one quickly that matches...
is the wheel not repairable car? if it is might be worth using it as a spare when you sort out a replacement wheel.
(27-11-2014, 02:32 PM)C.A.R. Wrote: That's not bad. I have Michelin PS2's on the front, so I'm not sure I'll even be able to find another one quickly that matches...
its not bad but its £62 more than I wanted to spend!
I've a spare cyclone if you're passing DN12 way anytime Smile
(27-11-2014, 02:36 PM)procta Wrote: is the wheel not repairable car? if it is might be worth using it as a spare when you sort out a replacement wheel.
Cyclones are dirt cheap anyway.
62k Diablo Phase 1 Gti-6:
Project Thread
It'll likely be one of those silly situations where it will work out cheaper to get a complete set of cyclones than buying a single!
Glad your ok though dude, could have been a lot worse!
HDi Cabby Project Click
I'm sure someone on here could sell him one cheaply.
Project Thread
Hmm, that's not good!
I saw a massive lump of scrap metal fall out of a scrap container lorry over a bump last week. Fortunately fell towards the verge not towards me but I did wonder how often it happens!!
