	Threads: 46
6
Car Model/Spec: Renault Scenic 2.0
	Given 6 thank(s) in 6 post(s)
		i'd like to get my remote CL working, but the fob i have isn't from this car, i had to change the locks over a while ago and got this key with it, it's the IR type, 2 button, new batteries so everything lights up as it should
i was wondering if it was a peugeot job to get this working, or whether theres some way to sync it to the unit in the car?
Project: Formula Peugeot
	Threads: 87
48
		You can do it yourself, do a google search if you struggle I'll walk u through it, not hard at all
	Threads: 87
48
		 (24-11-2014, 06:02 PM)John1.4 Wrote:  well searched google, and came up with 2 variations of how to do it, one from the GTI6oc, one that pops up pretty much everywhere, tried both, no joy...
it says to hold the large button for about 20 seconds until the led flashes, then press the small one, but when i press and hold the large button, it flashes once as it normally would, then doesn't do anything...
it needs to be done within 30secs of unlocking the car iirc, also make sure all doors are shut . .
