Rf key
Is there any way to check the rf key fob is working my central locking works with door barrell but not butyon iv tried sync but none of ways work
Presume the battery is good? The only way to sync them I've found is with Peugeot Planet (diagnostic software). Someone might be able to help you on here if they have the lead and software local to you.
Oh you'll also need the 4 digit key code to code it with Peugeot planet too.
Use the camera on your phone to look at the infrared light at the top of your key to see if you can see it Flash when you pass the buttons.
If no flag try a new battery
That's a great tip for the older infra red fobs, but doesn't work with RF sadly.
My uncle has peugeot planet cheerz will need get the code and yeah batt brand new cheerz
I now know the remote key is working any ideas what next i can be checking
