Tyre psi
What psi would you recommend for cyclones on an estate?
I run my hatch on 35 psi. Should be in your book somewhere Smile
As grant says about 35/36 psi. It sound say on the drivers door
35/36 is quite high.
I run my fronts at 33 and rears at 32 and Im seeing the centres wearing a little, which indicates too high pressure.
It says 2.5 bar which is 35 psi on my hatchback.
Depends on the tyre and the size really
GT2052s DTurbo
OEM+ HDI Estate
Project thread
It does say on the door 2.4 bar but that's the original tyres isn't it
[Image: e0d4ac7c-727f-46a8-ae0c-d4a324a8a667_zpsyn3ibroz.jpg]
32psi on 14's and 35-36 on 15's is the Haynes book figures iirc . . . . .and i don't get and centre wear, go figure . .Smile
