Got my new daily 307 HDi 02 reg nice a cheap cus it's in limp home mode the code is p0193 fuel pressure fault any help thanks
307 HDi fault
21-03-2014, 03:57 PM
Was cheap for a reason then.... gotta be a fuel pressure sensor of some sort, James should have a couple to swap with??
21-03-2014, 05:57 PM
Won't be the fuel pressure sensor, more likely the fuel pressure regulator or the fuel pump. Read the FAQ section on my website, lots of useful info on there.
21-03-2014, 06:37 PM
Yep found the fault in the end bit of a strange one think someone been playing traced fault back to a broken pin on ecu runs fine now temp repaire for now will sort proper when got time still a little jerky when driving but hasent been service in a while I would say
![[Image: mike_sig_zpsd438fb98.jpg]](http://i307.photobucket.com/albums/nn313/rallymark1/306oc%20Forum/mike_sig_zpsd438fb98.jpg)
