Air filter ph1
How do I change the filter on a ph1 the box is circular and has pipes and wires. I got a cone filter what am I supposed to do with these wires? Or can I take the old filter out clean out the box and attach to the box? Pics would be great to Wink
Moved to the correct section.
Thank you
undo the top bit, take it off and then undo the filter housing off the coilpack bracket... then throw it away (the pipe going towards the front can be gotten rid of, keep the other one)
if it's for the cone filter you have 2 choices, run some piping to the underside of the top section and put the filter down the front, or put the filter where the airbox was
Project: Formula Peugeot
So what am I supposed to do with the other that connects to the top of the head ?
[attachment=12712]
you can see the filter at the back, the silver crap was an attempt at a cold air feed, although if i was going to do it again, i'd have the filter at the front with piping leading to the back
