Gearbox crunching?
My bro has a problem. His car started to crunch when going into 4th. He has a quick shift so though it could be that. So he for a hdi box and fitted that now that crunches in 3Rd. So he changed it to a stock gear stick and links and it's still doing it. Is it just Shit luck and 2 fooked gearboxes
[Image: sig-1.jpg]
SOLD
Yeah I'd imagine its just bad luck. How bad does it crunch? I used to have a box that crunched slightly into 4th unless you were very careful with the change. Never got any worse in the 15k I used it though.
[Image: 20120704_212316.jpg]
Knackard sycro in box, it's common on the xuds
(08-04-2013, 05:50 PM)Ben Wrote: Yeah I'd imagine its just bad luck. How bad does it crunch? I used to have a box that crunched slightly into 4th unless you were very careful with the change. Never got any worse in the 15k I used it though.
same, it doesnt do it if you very slowly go into gear, worse on the downshift.
(08-04-2013, 06:17 PM)dturbopeck Wrote: Knackard sycro in box, it's common on the xuds
and its a hdi box and still does it
[Image: sig-1.jpg]
SOLD
