03-04-2013, 09:31 PM
Hang on, so did you actually find out what had seized it in then? Can't think I've ever heard of a stuck driveshaft in a 'box...considering its permanently lubricated!
removing O/S driveshaft
Mine had seized in the mount before it took a good 40 minutes of smashing to get it out because the bearing was demolished.... I guess driving it round with the bearing knackered for 2+ years didnt do it any favours :p
Click to see how smokey is doing
----> Project Smokey
03-04-2013, 10:00 PM
04-04-2013, 06:29 AM
The bearing was removed from the block. The bearing Inside this was seized.
04-04-2013, 06:45 AM
so it wasnt seized in the diff?! im confused
04-04-2013, 07:41 PM
You can't get the mount off the block and shaft without the driveshaft out since it's got a dowel that holds it in the block?!
04-04-2013, 07:50 PM
Hmm ok....
![]() Not sure it makes sense but that is what I said the problem was the other day and you said it wasn't lol. ![]() (02-04-2013, 06:04 PM)ginge191 Wrote:(02-04-2013, 06:04 PM)Toms306 Wrote: The shaft has a bearing ring around it. Whack this ring out of the mount, towards the wheel end of the shaft obviously. Fair do's though, thats the same issue with all of them.....infact I couldnt get rowells back in either so resorted to a hammer and crowbar....cut the f*cking cv boot didnt I! I'm guessing I shoulda lubed the bearing before trying to put it back, learn from mistakes though, I'll give him the one off my HDi instead.
06-04-2013, 11:17 AM
(04-04-2013, 07:41 PM)Ruan Wrote: You can't get the mount off the block and shaft without the driveshaft out since it's got a dowel that holds it in the block?! The locating dowells were away from the mount - it was levered(?) far enough away to move freely - hence we could smash it off oncc the engine was out
