Threads: 252
7
As there both Pull type clutches what power can the Gti6 clutch take? Do people that run high boost chargers run standard clutches on the Gti6?
TD04 11mm Sedan, now 2.1 vnt
Sedan Project
http://306oc.co.uk/forum/thread-5763.html
Provence Dturbo Dead
Blaze 1.6 Dead
Threads: 252
7
Ok cheers I have a brand spanking new gti clutch so was going to fit that to my DT only going to be running t2 with 11mm and fm so not mega power so should be fine. Was not sure if they were designed to the engine type that's all. Cheers Dan
Sedan Project
Blaze 1.6 Dead
You'll be fine with a DT clutch...
I think the GTi6 clutch has a very slightly heavier pressure plate... but it's negligible.
Threads: 252
7
I know but that then means buying one where I have a gti one in the shed
Sedan Project
Blaze 1.6 Dead
