Full Version: TD04 Questions
I am looking to go down the TD04 Turbo route..
When looking for one what codes do i need to be on the hunt for
For example: TD04 L ?
& i seen someone on here selling adapter plates and a high pressure line to fit, but what about the low pressure line, what do you use etc?
Any help appreciated thanks. PM if you have one for sale etc.
Buy my complete bolt on kit AND the pump Smile
The return just needs a longer piece of rubber putting in place tbh
OR pick up a turbo for £50, adapter plates for £65, oil line for £25 and pump for £75 with lines and injectors if you don't already have a Bosch pump.
Everything you need for £215...
OK, so ive found a turbo on eBay. Its off a Impreza WRX V4 and it says its a TD04-L Turbo.
Heres a picture of it:-
[Image: %24%28KGrHqN,!oMFC2ZUoVclBQwHnhmdPg~~60_12.JPG]
Is this what im after?
Looks ok. Try and avoid any with the code ending in 501, the turbine is a bit big.
looks right...shouldnt have to pay more than 50quid for it with minimal play
Td04l 13t is the Scooby variant that people generally go for
