07-08-2012, 04:51 PM
Modifications
9mm pump
Solid gov
Lda mods
T25
Defiltered
Dewastegate around 30psi
Currently running veg. on a run put the foot flat to floor in 3rd the car hesitated rattled from the pump bogged a tad then caught up with itself took the car upto 4-5k hitting 30ish boost next thing it's like the turbo sucked something or fuel got restricted or poped a pipe As I lost all boost and power. The car still ran fine idled fine and drove fine except billowing smoke out. I could here the turbo still running with a slight whine which was there before. Limped the car home under 3k no foot flat action due to smoke obviously was slow and assumed that was what driving a nad was like. Got home no boost leaks no poped hoses still no boost. Took car for a quick run took it to 3k foot flat pummeled smoke then bogged out to point of stalling. anything over 3k with more than a quarter throttle its just bogs and rattles like mad. I'm suspecting that possible the pump has been starved and maybe stuck a vane? But why no sign of boost?
Things checked are timing
Boost pipes
Actuator arm
Fuel filter
Pickup strainer was checked less than a week ago and clear
Any ideas would be appreciate
Cheers
9mm pump
Solid gov
Lda mods
T25
Defiltered
Boost pipes
Actuator arm
Fuel filter
Cheers
