Alright iv just purchased a mbc off the bay , iv got a general idea of how to fit just wondering if anyone could confirm my thinking ?
Get under car , cut metal pipe (im on k14) in half from turbo outlet to actuator bend apart so I can slide silicon hose on feed up to top of the engine bay where the mbc will be sat connect silicon the appropriate places on mbc and were done?
Is this right? Does anyone have any cheeky little tips to do it any easier
And how do you secure silicone onto cut pipe on the turbo as I don't think iv ever seen jubalu clips small enough lol
Cheers guys
Little jubilee or similar to hold it on the turbo. There are some about should be fine but yeah got it in kne
Sounds right to me.
I'm sure cable ties will help but I'd doubt they would pop off anyway without. Just make sure you push them on as much as you can.
Is it a metal pipe on the k14? On a T2 it is a rubber hose which goes from the compressor housing to the actuator, cut this, fit mbc. Done! But make sure you install it the correct way, the arrow on the mbc will point to the actuator iirc.
Cheers as soon as it comes I'll have a bash at it and report back if I have any troubles can't see it though it seems really straight forward , what did people use to cut the pipe will a pair of snips do the job then pliers to make the pipe round again or is it a hacksaw blade job. Also has anyone ever mounted a mbc in the cabin ?
What type of MBC have you bought? is it a ball bearing one or a boost leak one? if its the latter then start again
It's a proper mbc so the ad stated not a leak of valve thing the make is r-spec seems really good quality tbf
(30-06-2012, 10:49 AM)Jackabeen Wrote: [ -> ]It's a proper mbc so the ad stated not a leak of valve thing the make is r-spec seems really good quality tbf
Hmmm.........do you install it using a tee piece? Pics would be helpful
I'm not trying to be a pain, there is just no point fitting something shit....
you know where i am jack lol! you need the boost source feed to come up through the bottom of the mbc often shown with an arrow
