Is there an easy way of removing injectors from my car without an injector tool? From what I remember of doing my old engine I stuggled like f*ck to take them out..
Plus side injector seals were £6.40 for 4 from pug
What engine? If its dturbo, 27mm deep socket from halfords then return it after
Sent from my HTC Wildfire using Tapatalk
27mm draper deep socket is about 6 quid on ebay . . . .you'll want to use a breaker bar as well . .
(20-06-2012, 03:35 PM)Diggers Wrote: [ -> ]What engine? If its dturbo, 27mm deep socket from halfords then return it after
halfords "DEEP" sockets are not deep enough FYI... the one i bought was as useful as a chocolate teapot
Draper deep sockets online suffice.
Or you could get a specific injector socket so you don't f*ck up the leak off connections on the injectors :rolleys:
Bunch of fooking pikeys I tell you!
you want this one -
http://www.ebay.co.uk/itm/Draper-Expert-...052wt_1004
Also FYI halfords do also sell injector sockets
(20-06-2012, 03:41 PM)ginge191 Wrote: [ -> ] (20-06-2012, 03:35 PM)Diggers Wrote: [ -> ]What engine? If its dturbo, 27mm deep socket from halfords then return it after
how deep you need it? :o
it worked for me, their diesel injector deep socket didnt fit thou
FYI Halfords 27mm normal deep socket works fine, plenty deep enough and never broken any leak off tabs.
(20-06-2012, 03:46 PM)mark_airey Wrote: [ -> ]Or you could get a specific injector socket so you don't f*ck up the leak off connections on the injectors :rolleys:
you want this one - http://www.ebay.co.uk/itm/Draper-Expert-...052wt_1004
cheers Mark, that's what i meant, that's what i got and was fine . .
The halfords one by me was useless aswell. Different ones must stock different injector sockets
(20-06-2012, 03:48 PM)Dan! Wrote: [ -> ]FYI Halfords 27mm normal deep socket works fine, plenty deep enough and never broken any leak off tabs.
thats the one i ment, hence why i just put 27mm deep not injector socket, cos the injector one doesnt go over the leak offs
