28-05-2012, 08:23 PM
As most off you no my pride and joy was written off a while back by an old git not looking where he was going,so after a couple weeks of looking for a replacement car i got this
:love :love :love :love
the plans for the beast
GOOD f*ckING CLEAN!!! WAX CLAY BAR YOU NAME IT
refit all the archliners
waxoil/paint arches and under the car
paint side strips
paint or maybe carbon spoiler
fit lightend fly and pullies
refit carpet
fit my vipercross
fit my miles beam mounts
rebuild the beam with my fresh tube with new bearings
sunstrip
new wheels
paint calipers
new bonnet sticker
and on and on and on:whistle
So I began. Thought to myself lets sort that f**king car out. so i started by taking the rallye seats out and cleaning the whole of the inside
after 20mins of hoovering and attacking with the sponge i was happy ish
but then i decided that i really didn't want to see the horrible floor so i ran over to the six(less than a foot behind me) and attacked the carpet. Great fun getting it out lol gave it a good clean and pop it in
i then put the central trim back in with my handbrake cover,not sure on the gear knob at the mo may put a standard one back on when i find my nice fresh one hidden somewhere
after this i went and got my lovely bucket seats gave them and clean and dropped them in
interior for now DONE!
i then turned my attention to the outside of the car. first petrol trim
I then got rather busy collecting parts and painting like crazy!!!!!
also took my old engine apart with intensions to just change the stem seals.............until i noticed the waterjacket on the gasket was soon about to go so i then decided to rebuild the whole thing. having great fun tearing it apart with paul.
rallye wise i replaced the beam with my beam tube that has ok bearings and took the 21tbs out because one of the end bolts had snapped!!!!!the car is now sat on its ass till i sort this :LOL took her out for a spin........noise coming from the front end.......ahhhh topmounts......ah missing washer for top mounts,ah well got mine at home. then noticed its unsettled when putting you foot down.......hmmm play in rack ahh also ball joint not the best so wack them on order. radiator pressurising???????? rebleed sorted it for the mean time but green coolant???????
then fitted my nice fresh carpet in the rear and fitted my new boot badge and didnt touch her for a week.
feeling good ........................................................until I went for a 50mile drive with my mate paul (because he is bedding in fresh engine rebuild) bugs everywhere so had to spray the window clean........wind window up as you do and put cold air fan on.........nice fuel smell!!!!!!
cams run lean so dont worry. then found and lovely road at least 7miles long which is just awesome so i fought "lets see what you can do" f*ck ME was great the rallye just pulled then went all boggy and odd..............pull over pop the tank.......................................................................................................
f*ckING HEADGASKET :ANGRY
so another day attacking the rallye, woke up and decided to rip the fans and rad off because the headgasket had gone. nice enough everything came off nice and easy.
once i had this all out i noticed some rust so i attacked it with the wire brush and sander and krust and then painted it all back up.
while i was at it i sanded and painted the front brakes and took the wishbones off to replace with mine
before attacking the wishbones i put some new ball joints on mine
then the problems started........first was the trackrod end which refused to come off.......so i hacked it off then the droplink did the same....so i hacked it off then noticed both ball joint pinch bolts were over tighten lucky enough the hubs aren't ovalled. So i moved to the front of the car again and decided i dont like the one fan set up on the rallye so..............
after hacking the six on apart i now have a twin fan set up. one fan will be a manual switch while the other is auto.
that done I then turn my attention to the power steering which has been relocated and not fitted correctly. Its ment to fit in to the holes with the shoulder spacers/dowls and guess what.........yeap you guessed it NOT FITTED.because of this the belt makes a horried noise whinning so i thought i start taking it off..................................
whats wrong with this picture??????
Then the fun began
:evil: :evil: :evil: :evil: :evil: :evil:
Coolant in cylinders 1 & 4
Coolant in exhaust manifold, collector number 4 is submerged in coolant
Blocks had been decked by the looks of things
Engines not the original engine. Early pulleys along with the 136t tensioner. Should be a 137t setup being a t reg. Sooooooooooooo took the engines out and it was completly dead. Cranks had it, heads had it, blocks had it, powersteering pumps had it, gearbox mount has had it, engine cradle has had it.........but on the bright side the cams are fine ...............................or really. Turns out they were standard cams :evil: :evil: :evil:
not a lot of gearbox oil
then the cleaning and the prep
then the new bits
apart from this i had done some more painting and that was about it my mate paul picked up my nice redone crank and bottom end bearings :cool THANK YOU PAUL AND MILES once again.
so another morning on the rallye............off to pug to pick up some parts "my banks going to love me"
picked up my oil chain cog, selector bushes and some power steering fluid "dam ive got an oil collection goin"
i then quickly fitted the bushes before i headed off to my physio
After getting SMASHED by the physio bird i went to go and collect another part from my local auto factors.....nice new shiney fan swicth. so i rushed home and fitted it
i then fitted my newish ecu sensor
and i was going to leave it at that but.......................................i got carried away lol
i then ripped the rallye power steering metal pipe off because it was bent
and fitted the one off the gti and once again got carried away
not sure if your ment to paint this but oh well.
then I sat indoors hurting.
been a while and paul and myself have had been busy as ever:yes and god is it taking its toll on me......but enough of my moaning. A couple more bits...... my bearing turned up thanks to MR RICH again so we set about attacking the bottom end:rolleyes
loads of nice new stuff uprated and standard bearings,new oil chain and cog new bottom pullie and a nice thick repair gasket for furture cams or advancing :devil
we then called it a night
the following day i then did some more painting while waiting for paul to arive then once again back on the the car
popped the head on timed her up fitted the mani and popped the pas kit on to see how it goes and left it at that.
then had a night off of the car and had a night in with the misses...........it went well....started talking about engine bedding in process in my sleep:lol :lol :lol
another day passes and i get fed up of trying to contact Mr bm baker and decide to take a gamble and be a ginnie pig
perfectly happy with their p bushes so why no try a vibratechnics gearbox mount. can service it and all.
Once again i was at it with paul managed to fit the pas kit correctly by using some seatbelt spacers:ban re fitted the belt popped a new crank seal on then the flywheel and clutch cover and thats it
done some more work on ole money pit today....... but i first had to clean the garage out because it was looking like the tip 2hours later i managed to finally be able to see the floor and my wheels again thus giving me the perfect excuss to pop them on to see how nice they are
still not sure weather tho keep them white or not but then simonjames has his white and it looks lush but i dont want to be a copy cat :LOL
after this i then put the gti clocks in.....glad i did the rallye ones were held in by two bolts!!!!!! one to hold the surround and the other to hold the clocks
after this i then tighten up all the bolts from the night before on the engine
Done a couple more things to the rallye.......the engines in, battery all connected, driveshafts in, engine oil in, top mount bearings in, new ball joint bolts and fitted new droplinks. Turned the engine over and it seems all good. now got to just put the plugs and coilpacks in and see if it fires up :dance: :dance: :dance:
The miles the car was on when i got hit
filled up the gear box and the powersteering pump.........now the rad!
coolant now in new fuel filter fitted washer bottle and induction kit fitted front bumper fitted to. wired up the manual fan as well just got to fit it in the car...............almost their might be able to have a birthday drive!!!!!:hyper
Got the tre off thanks to paul 'need slitons in my life' also after fanny assing around i now have a level seat that slides what a ballache it was tho. Also fitted one of my lights and because winter is on the way and cause im blind i popped my hids back in :doh 'getting ready to be pulled'
Part from that greased the new tres and started putting my YELLOW cage padding on :hyper almost their
stupid me forgot to swap the slam panels over!!!!!! means i had to zip tie the front light bolting points for now until i can be asked to put my other one on :nope:
tracking done brakes bleed and went for the test drive..................................woohoo its works started really boggy at first but over time it picked up and pulled better and better as i kept driving. Two annoying things tho have an annoying noise from the starter motor and i have some chamber on the front passenger wheel??? part from that its going all good
Done a couple more miles in the car and decided to give her a wash at the same time i painted the wheels up black but i didnt like it that much so they went graphite grey
took me 5hours to clean the bloody thing and the pic do it no justice
i perfer the grey????
after this i then went to nur motorsport to see how i can spend my whiplash money..............if i get any
i took a couple pics of the car and of some things i want :hyper
carbon goodnees
apart from this all i now need to do is replace the clutch cable because for some reason mine has gone sticky
fit a new driver door central locking unit
weld up the cradle
get my new tyres
get a refurbed beam
and sort the alarm system out
and on and on and on lol
some pics
just enjoying the car. But I decided to buy myself a oilite conversion xsara beam and another set of bf goodrich tyres. next on the list is a peter t inlet cam and maybe a diff Love
also.....,due to money problems i sold my coilovers and got some b8's...................what a great idea it was.....car feels SO MUCH BETTER!!!!!!
Beam turned up. So I put it on and wooooooo what a difference......only annoying thing is i still have a rattle :angry i think its the rear shocks because they use metal bushes.
also got my new tyres so i have winter and summer tyres now
ahhh the better weather came back for a while,so i decided to fit my new speedo housing seal because it was leaking also fitted all new clips on all the power steering hoses because they to had a little drip.
and thanks to carl chambers i now have two keys and a full working lock set Smile "blip open"
blip lock. next repaint and fit my slampanel.
well during the weekend i decided to take off my slam panel becsuse i fitted the wrong one in the first place.....plus it looked tatty and the lights had to be ziptied on because the mounting points were f**ked......so on goes fresh painted panel:-)
old and new
much better
So i decided to start on the wheels again because they are a tad marked. while i was at it i repainted the strut brace and cleaned the engine bay
finished sparying the wheels,they are looking fresh again
And my decal set turned up. Its not 100% perfect but i only need the back and rallye decals
Now im just waiting for the nicer weather to clean her
Seeing as the rain has decided to stop i decided to give the rallye some TLC. So heres some pics for you all
and thanks to a great mate i got these on a pay when i can deal
and that leaves me to where I am at the moment. Recently I got myself and fitted an inlet bung, underseat sub and some new fixed omp subframes. Now just saving up for some more service parts and a helmet / shopping harness.
paint side strips
refit carpet
fit my vipercross
sunstrip
new wheels
paint calipers
new bonnet sticker
Then the fun began
then the new bits
carbon goodnees
weld up the cradle
get my new tyres
get a refurbed beam
some pics
old and new
much better
