Full Version: lower height pistons xud11 of 1 mm
Hello everyone
I wanted to know if there was a risk of destruction of the pistons which is reduced by 1 mm?
I will do a ceramic heat treatment
but it is that when we remove the material its weakens the pistons? is for a power of 250 to 300 hp
Bonjour a tous
je voulais savoir si il y avait un risque de destruction du pistons qui on le reduit de 1 mm?
je vais faire un traitement thermique en céramique?
mais es ce que quand on enlève de la matière sa fragilise le pistons s'est pour une puissance de 250 a 300 cv
quite unlikely they will hurt them, they are so big and heavy!
Slice that material off! If it's straight flat off the top will not be an issue has been done heaps of times
(21-02-2018, 10:22 PM)Dave Wrote: [ -> ]Slice that material off! If it's straight flat off the top will not be an issue has been done heaps of times
we can lower the volumetric ratio and what interest to do that?
do we protect the heatgasket?
I'm already in wrought rod I'm just afraid that for big powers with big turbo pressures the heatgasket does not fit ...
