Jumped in it today to pop and see family, there' a faint buzzing behind the dash with the ignition on, click the key to start position and nothing, the battery light comes on.
To accompany this, the clock won't come on and the radio is dead.
II' guessing something simple but what? Car starts fine when I cross the terminals on the starter.
1995 N reg d turbo by the way
Thanks for any input. Missing my tunes
Jump it. Sounds like flat battery
Sent from my Gemini using Tapatalk
Batteries perfect. Wouldn't be able to start it from crossing the starter motor connections if that was the case
Starter solinoid? Bad eaterh?
Why would the radio be dead, the clock not working and the quiet buzz from behind the dash at the same time as the starter not cranking though? Was running totally fine yesterday. Has confused me.
Think it's the earth from the gearbox to the chassis leg that's broke. Have you checked the earths?
I'll check earth's first think tomorrow.. the car is so bloody low to the ground I can barely get my arm underneath it haha.
Cleaned up earth's on the chassis leg and rebolted them.
Went to start car off the key and wouldn't turn over, started with screw driver across starter terminals. Jumped in car and radio had power, it turned on for a split second and went off again, same with the clock.
Couldn't find the chassis to gearbox earth so ran my own. Still won't fire off the key???
Do you think it possible the ignition live has fallen off the ignition barrel? I just can't think why there's no feed to the starter motor when the keys turned over and the radio and clock are constantly dead. Got continuity from the battery to all the earth locations in the engine bay now
If you can, test you are getting power to the starter solenoid when the key is turned.
Took it to an auto electrician today. Turns out there was an immobiliser on it which had cut in. The chap bypassed it and she's back in business
