Mrs Piggys 206 2.0HDi
Cold mornings, really sluggish to start. Turns over like a battery on its last legs.
Once started and running for a minute or so, it will start on the key.
Battery is a Bosch and only about a year old.
With a battery boosted pack on, no difference.
When it does fire up, cloud of exhaust fumes. A few coughs.
Also, climate control has reset itself and airbag light on. (Airbag light resets itself after the next time engine is off/on)
Not had time to get at the car properly, Mrs piggy using it and me busy...
Anyone had similar?!
Are you able to try a different battery? If the battery is properly dying a booster may not help.
try a diffrent battery as rowell says but i have had issues with sluggish stsarter motors being slow or bad earths. I would check battery then if its not that (which i doubt being you) swap the starter motor from the LEmoan its the same and see if it makes a difffrence. If you need a starter give me a shout ill post you one i have about 6. Just cover postage as its you. Also its unlikly to be glowplugs on these. Ive never really had an issue with the 2.0lts and glow plugs. I didnt even run any once through winter and it started on the button, obviouly being DI theyre a bit better.
Yeah it's not glowies I don't think...just not spinning fast enough.
My first inclination is starter as it had made funny noises earlier in the year...maybe drawing loads of amps.
Will check earth's too if I get a moment
(30-11-2017, 09:17 AM)Eeyore Wrote: [ -> ]Are you able to try a different battery? If the battery is properly dying a booster may not help.
Battery has tested fine
This booster will start a car without a battery so would expect it to help anyhow
I would say starter motor issue
Hdi's are fond of a sluggish starter motor, however the airbag light coming on then resetting suggests a low voltage.. this could be down to the starter drawing lots of amps though, I doubt the 1 year Bosch battery would be at fault.
(04-12-2017, 01:04 PM)Mitch Wrote: [ -> ]I doubt the 1 year Bosch battery would be at fault.
I would not discount it, the blue topped bosch silvers don't like a bit of volt drop and cold weather and lazy starters.
not saying its directly at fault but they can suffer a bit.
(04-12-2017, 01:53 PM)welshpug Wrote: [ -> ] (04-12-2017, 01:04 PM)Mitch Wrote: [ -> ]I doubt the 1 year Bosch battery would be at fault.
Ahh well in that case then, thinking about it the last two battery's I've replaced of my own have both been blue tops.
Sent from my EVA-L09 using Tapatalk
I've seen a lot of shit Bosch batteries in recent years. At least try another battery if you've got one.
I would expect its a lazy starter.
So despite the battery passing usual tests... Put it on a trickle charger overnight and the thing started much better.
So either;
Duff battery
Power drain
Easy test: disconnect it overnight and see if it helps.
Time for a parasitic battery drain test then.. although I'd still suspect the starter simply from the amount of lazy hdi ones I've replaced.
Started fine today... #facepalm
It probably started ok as it's not been as cold.
I've had this the last couple of weeks on my car.
I to thought it was the battery and charged it and found it better after that charge then went the same the next day. I checked the voltage before starting and it was healthy but still turned over slowly.
The symptoms I had were the same. First start of the day slow, the rest ok.
The clocks would do the swiping thing.
I thought I'd take a look at the starter thinking the solenoid was getting gummed up and not moving freely.
I gave it a clean, it didn't look to bad to my surprise. I gave it a very light film of grease.
Next I moved on the earths. I found a layer crap on the crimp ring and mating surface of the lug on the gearbox it bolts to.
I cleaned it all up and now the engine spins over so quickly, it's awesome.
Earth's are fine. Been checked.
Is it a valeo starter motor on yours?
Take it for a proper drop style load test and see what AH it’s actallt is, probably down to 200 or something.
I had a bosch s5 and it lasted less than a year. The silverline range is properly useless especially when it costs so much.
Bosch s5 here, 3 years old and dying!
