Full Version: Tell me how to spend some money pls.. turbo options?
Hi, I wanna go faster Smile
Current car specs are : 2dr 205 fitted with a NA DW8 block with XUD9 intake & exhaust manifolds with KKK turbo and unmodded Bosch fuel pump. No intercooler whatsoever, just turbo outlet literally connected to intake plus a boost readout for pump. Spool is quick to say the least..
Car already goes down the road like a scared monkey on meth but turbo is puking oil out the intake so most probably seals are gone.. Makes sense to me to upgrade to something better. A nice twin-pass intercooler will be added to the car when the new turbo is here, plus it will be gearbox mounted most probably.
The goal is a quick spooling, reliable-ish 150-160hp with room for it to go to 180-190 when i upgrade to a 10mm or 11mm pump plus ARP headstuds. Would love it to go over 200 but custom conrods are a bit out of budget for now..
Candidates are:
The Merc GT20
The Volvo GT2052v
The Audi GT2052v (what are the differences except the obvious visual ones?)
The BMW GT2256v
Any others I should consider? Opinions? Thanks for the input!!
A decent block be a much better start...
Then when you do, get some ARPs and a decent HG ready for that nice modern blower.
GT2056s or v or GTB2056
yup, would not be surprised if the NA bottom end shits itself soon enough, the TD is stronger and has better cooling, also lower compression and bigger injectors as standard.
What are the differences between the blocks? Crank, conrods and pistons? Injectors may have been changed prior to buying, is there a way to make sure? What do you mean by better cooling?
Also, Piggy, GTB2056? Never heard of it.. know someone who fitted it? are you speaking from experience?
Thanks for the replies and suggestions Smile
Google it. It's been superceded a few times already. But it's a cheapish turbo now and very capable. Yes, use them on my motors.
Block/rods/crank are all different. Amazed it hasn't blown already on the dw8 block tbh
Do dt rods and crank fit a dw8?
On another note.. does a dw8 head fit the xud block? I'm asking because i am a surprised as you are about it holding boost and not turning everything into mush.. could it be that they only changed the head? And all the rest is normal XUD stuff? Is there any way i can distinguish between the blocks?
Thanks and sorry for all the noob q's.. Smile
just get the whole engine.
I know this is an old thread but yes to answer the question, a dw8 head fits a xud block as is the case with my dturbo, some say it gives better performance but I  don't believe this due to different cams etc..
(30-09-2018, 02:31 PM)zack Wrote: [ -> ]I know this is an old thread but yes to answer the question, a dw8 head fits a xud block as is the case with my dturbo, some say it gives better performance but I  don't believe this due to different cams etc..
To be honest, those blowers on low boost/low egt/low emp will yield heaps more power and be cooler than a t2/k14 screaming itself with hot air.
If it was running 12psi of boost it would see 5k no issues on a NA block. Not making power with torque doing it with revs and amodded 9mm pump would be ideal. Never gonna make 200ftlb but on a nad block you dont need to, hit it with revs and this block would be ok and be much more fun/reliable than 20psi with stock blower taken to 4k.
Best bet is to just get whole new engine as said though
