11-09-2017, 09:47 AM
11-09-2017, 10:16 AM
well, if you support the engine underneath, loosen the top engine mount, rock the engine towards you by slowly letting the jack down, you should have enough room down the back of the engine to change it, anything else you need?
11-09-2017, 10:59 AM
Thank you. If I just want to modify it? Wastegate?
(11-09-2017, 10:16 AM)Mattcheese31 Wrote: [ -> ]well, if you support the engine underneath, loosen the top engine mount, rock the engine towards you by slowly letting the jack down, you should have enough room down the back of the engine to change it, anything else you need?
11-09-2017, 12:32 PM
Up from under subframe to turn it up.
