Hi everybody
I have an impossible problem to adjust the pressure to 1.1 bar with my gt2056s.
I regulate the wastegate at minimum and the pressure rises to 1.7 bar and more I can not regulate less.
To be accurate 2 ime 1.4 bar 3 and 4 ime 1.7 bar and 5 th 1.8 bar.
I disassembled the turbo and I adjusted the westegate to 1.2 bar but the same in the acceleration its regulates to 1.7 bar.
Has anyone had this kind of problem?
The gt2056s is brand new out of factory.
Salut a tous
j ai un problème impossible de régler la pression a 1.1 bar avec mon gt2056s .
je règle la wastegate au minimun et la pression monte a 1.7 bar et plus je n arrive pas a réguler moins.
pour étre précis 2 iéme 1.4 bar 3 et 4 iéme 1.7 bar et 5 ième 1.8 bar.
j ai démonté le turbo et j ai réglé la westegate a 1.2 bar mais pareil en l'accélération sa régule a 1.7 bar.
est ce que quelqu' un a eu ce genre de problème ?
le gt2056s est tout neuf sorti d usine.
Is the waste gate connected directly to the turbo, or does it go through a manual boost controller?
Either the wastegate is not opening enough for exhaust flow of engine - doubtful
Or control via wastegate is not working properly.
Either actuator is not moving enough (at 1.1 bar) to open wastegate enough to drop boost to target.
or manual boost controller not working correctly.
(19-03-2017, 08:25 AM)zx_volcane Wrote: [ -> ]Either the wastegate is not opening enough for exhaust flow of engine - doubtful
Thank you for your answers
I think that was the exhaust plate that is not suitable.
This plate model is good:
http://www.ebay.com/itm/Stainless-GT2056...211a74d9c0 : G: C5wAAOSwo4pYJ32U
Me the platen I have at this moment is flat it is 1 centimeter thick everywhere and I think the gas flow is too braked.
I took this turntable from a td04 I think s was a mistake.
merci pour vos réponses
je pense que s'est la plaque d échappement qui n est pas adapté .
ce modèle de plaque est le bon :
http://www.ebay.fr/itm/Stainless-GT2056S...Swo4pYJ32U
moi la platine que j ai en ce moment est plate elle fait 1 centimètre d épaisseur partout et je pense que le flux des gaz est trop freiné .
j ai pris cette platine d un td04 je pense que s était une erreur.
(18-03-2017, 08:45 PM)niciou Wrote: [ -> ]Hi everybody
Salut a tous
Yes. Mine did the same but ran 2 bar. I'd bought a cheap manual boost controller with no instructions and aftrr swapping it to a Dawes type controller and piping it up correctly all is under control. It went like a Lambo on 2 bar though, and then shat its turbo.
(21-03-2017, 08:49 PM)399road Wrote: [ -> ] (18-03-2017, 08:45 PM)niciou Wrote: [ -> ]Hi everybody
Salut a tous
I think the turbo is new and the westegate also
I removed the turbo and tested the westegate alone it is ok
I think I have a problem with the turbo bridle I think there is no place to get the exhaust out
Relief valve does not open sufficiently because of the exhaust flange.
This weekend surely I will have the new bridle I will make a picture of the 2 brides.
I 'm me who is not thoughtful and made a mistake in this place I think
je pense pas le turbo est neuf et la westegate aussi
j ai enlevé le turbo et testé la westegate seule elle es ok
moi je pense que j ai un problème avec la bride de sorti de turbo je pense qu il n y a pas de place pour faire sortir les gaz d échappement la
soupape de décharge ne s'ouvre pas suffisamment a cause de la bride d échappement.
ce week end surement que j aurai la nouvelle bride je vous ferez une photo des 2 brides .
s 'est moi qui es pas réfléchie et fait une erreur a cet endroit je pense .
(22-03-2017, 08:53 PM)niciou Wrote: [ -> ] (21-03-2017, 08:49 PM)399road Wrote: [ -> ] (18-03-2017, 08:45 PM)niciou Wrote: [ -> ]Hi everybody
Salut a tous
Hi everybody
I received a week ago the turbo bridle and the breakdown is the same trubo
Spool at 1.4 bar at 2800 rpm and at 3500 rpm the pressure rises to 1.8 bar.
I will buy a turbo faucet to lower the turbo pressure.
If its not walking with a turbo faucet I really see no or is the breakdown.
Can be the valve that is too small on this model of turbo ...
(30-03-2017, 06:41 PM)niciou Wrote: [ -> ] (22-03-2017, 08:53 PM)niciou Wrote: [ -> ] (21-03-2017, 08:49 PM)399road Wrote: [ -> ] (18-03-2017, 08:45 PM)niciou Wrote: [ -> ]Hi everybody
Salut a tous
Hi everybody
