my ph3 estate
pasaanger side door window seal leaking
dripping on to speaker inside door
and coming into footwell
what the best way to fix this
take door panel off; I used a large sheet of clear pvc sheet to make up a 2nd door membrane that I fitted inside the door---water was pissing in around the mirrors foam gasket. it caught any water from the mirror and the window and carried it into the bottom of the door. I then made up a new outer membrane (the one that's behind door panel) and used double sided foam tape to keep it in place........about 2 -3 years ago.
(06-11-2016, 07:39 PM)daddyfixit Wrote: [ -> ]take door panel off; I used a large sheet of clear pvc sheet to make up a 2nd door membrane that I fitted inside the door---water was pissing in around the mirrors foam gasket. it caught any water from the mirror and the window and carried it into the bottom of the door. I then made up a new outer membrane (the one that's behind door panel) and used double sided foam tape to keep it in place........about 2 -3 years ago.
Cheers mate all give it ago
yep, had same problem, made repair sheets out of blue plastic builders sheet and taped well with duct tape, worked a treat. pug oe wanted something like £40 for the part.
(06-11-2016, 11:17 PM)pug306driver Wrote: [ -> ]yep, had same problem, made repair sheets out of blue plastic builders sheet and taped well with duct tape, worked a treat. pug oe wanted something like £40 for the part.
All try it with the plastic i use at work cheers lads
Believe it or not, water is meant to enter into the door
There's two drains at the bottom corners, get a coathanger and make sure those drain can empty the water out efficiently! If that doesn't work, take off the doorcard and make sure all the membranes are in place and stuck on properly as said above.
(08-11-2016, 12:18 AM)BiG K Wrote: [ -> ]Believe it or not, water is meant to enter into the door There's two drains at the bottom corners, get a coathanger and make sure those drain can empty the water out efficiently! If that doesn't work, take off the doorcard and make sure all the membranes are in place and stuck on properly as said above.
Yeah need covering the door so got some plastic sheating from work
