23-05-2016, 08:23 PM
23-05-2016, 08:25 PM
Just preference...
Slightly better brakes which are cheaper
Even better brakes which are a bit more expensive and need minimum 15" wheels
23-05-2016, 08:26 PM
GTI brakes are bigger that HDI
23-05-2016, 10:16 PM
Gti 6 it is then
Cheers
Cheers
25-05-2016, 07:01 PM
I used Peugeot 307 2.0 HDi 282mm calipers & discs to upgrade my HDi. Made a huge difference to braking when above 50mph!
307 - Calipers and Pads are cheaper. Discs cost more.
GTI6 - Discs are cheaper, pads are more expensive. Has a slightly larger piston size so may be more force there.
26-05-2016, 04:17 PM
I've done the conversion to 266mm HDi brakes and callipers, it's relatively simple but a quick tip make sure you can loosen off the brake bleed screws of your donor callipers before you buy- nothing more annoying than a snapping one later at home. I'd also get the master cylinder out of the same car. GTi-6 brakes seem to be the ones everyone wants but I've found HDi ones perfectly adequate for my needs they're also cheaper and more plentiful to source.
26-05-2016, 09:33 PM
The master cylinder for the hdi is only Marginally smaller and much more common
26-05-2016, 10:30 PM
(26-05-2016, 09:33 PM)toseland Wrote: [ -> ]The master cylinder for the hdi is only Marginally smaller and much more common
Didn't some hdis have the same master as the gti6?
Sent from my GT-N8010 using Tapatalk
27-05-2016, 08:29 AM
Everything had the 23mm MC from mid X reg afaik, same time everything got 266mm brakes from 1.4 to XSi.
27-05-2016, 08:54 AM
Worth remembering that there is a downside to brakes larger than you need - more weight, and more to the point, unsprung and (in the case of the disks) rotational weight which is particularly undesirable.
27-05-2016, 07:50 PM
307/GTI6 discs do weigh a fair bit more, however if anything, I find it makes the front end feel a bit more solid. Steering wheel gets a bit heavier, about it really. The improvement in braking force is worth it though.
