not sure which tread to post this in.
So, having got a s/h cooler I was wondering which way up I should mount it;
hose unions to the top, or hose unions to the bottom?
not sure which way is best for future oil changes.
that could settle all arguments
You'll need to add sideways to the poll now.
Is it being mounted lower than the sandwich plate? If so, it won't drain back to the sump for oil changes anyway. If not, unions down would be good. But does leave the opportunity for minor union leaks on the drive while parked.
(28-12-2015, 10:16 PM)Toms306 Wrote: [ -> ]You'll need to add sideways to the poll now.
until I get the front off, I only know I want to mount it in front of the air-con
(looks like I cannot change the poll :/ )
updated the poll for you
fitted mine with fittings to the top
reason....
no airlocks
ease of fitting at centre of the rad
Mines with fittings at the top behind the radiator. Leaves a very short hose run which is nice.
(29-12-2015, 09:28 AM)cully Wrote: [ -> ]updated the poll for you
reason....
no airlocks
thanks for doing that Cully
