28-12-2015, 04:39 PM
28-12-2015, 05:07 PM
I'd stick with the dturbo clutch setup.
Means swapping the clutch arm over
Means you haven't got to change the clutch cable either
28-12-2015, 05:58 PM
Can it be run with hdi clutch if the cable is swapped over?
28-12-2015, 06:15 PM
You'll need to swap the flywheel to a hdi fly wheel as it's a bigger diameter) ,source some clutch cover bolts (different size to dturbo) and replace the flywheel bolts with new ones (don't reuse old ones)
Hdi flywheel weighs over 4kg more than a dturbo flywheel
28-12-2015, 06:21 PM
also youll loose the rev counter that way as well
28-12-2015, 10:27 PM
Sucks to have those text's from you today mate, sounds like it wasn't going as planned!
This is interesting to know though, as I'm hoping to do a clutch change & HDI gearbox upgrade on my D Turbo at some point.
Best method then --
HDI gearbox, swap fork over from D Turbo
Use D Turbo flywheel & clutch
Use D Turbo clutch cable
Use all original D Turbo bolts?
Is that all correct?
Best method then --
28-12-2015, 11:46 PM
/\ thats what i did also need the clutch cable holder part of the xud box
29-12-2015, 12:45 AM
(28-12-2015, 10:27 PM)Dazecoop Wrote: [ -> ]Sucks to have those text's from you today mate, sounds like it wasn't going as planned!
Best method then --
Correct, as above, you need the clutch cable holder, but this is already on your DT box.
Also, whilst you're at it, replace the plastic nylon bushes the fork sits in, these wear and make the clutch feel like turd, it's not a bad shout to change the cable (and obvs clutch) whilst you're at it - it'll feel like new after that.
29-12-2015, 09:16 AM
(29-12-2015, 12:45 AM)Ruan Wrote: [ -> ](28-12-2015, 10:27 PM)Dazecoop Wrote: [ -> ]Sucks to have those text's from you today mate, sounds like it wasn't going as planned!
Best method then --
Cool, cheers. Good to know!
29-12-2015, 10:06 AM
New clutch has just arrived time to rebuild hope it all goes well today
30-12-2015, 08:36 PM
Omg after all the sore fingers and broken parts I'm finally back together and going good had it out a good blast there and I must say its well worth changing to the hdi box I love it!!!!!
