02-05-2012, 06:11 PM
02-05-2012, 06:43 PM
I think the one you want is a td04 13L if memory serves, not a 13g or 13hl, don't know about the t's.
Sure someone will be along with slightly more useful info soon enough lol.
EDIT: Warning: Relying purely on info read on tinterwebz, no actual knowledge contained within this post.
02-05-2012, 07:20 PM
http://www.stealth316.com/2-3s-compflowmaps.htm
MHI Turbine Wheels
Wheel Exducer (in.) Inducer (in.) Trim
TD04 1.57 1.86 71
TD04L 1.62 1.86 76
TD04H 1.74 2.04 73
TD04HL 1.80 2.05 77
TE04H 1.88 2.01 87
MHI Turbine Wheels
Wheel Exducer (mm) Inducer (mm) Trim
TD04 40.0 47.2 71
TD04L 41.1 47.2 76
TD04H 44.2 51.8 73
TD04HL 45.6 52.0 77
TE04H 47.8 51.0 87
Turbocharger Wheel-Size Comparison
Turbo Compressor
Wheel Inducer Diameter(in.) Exducer Diameter(in.) Trim Housing
TD04-09B 9B 1.365 1.930 50 TD04-09B
TD04-13G 13G 1.580 2.000 62 TD04-13G
TD04-13T 13T 1.597 2.203 53 TD04HL-13T
TD04-15G 15G 1.625 2.187 55 TD04-13G bored
TD04H-15G 15G 1.625 2.187 55 TD04H-15G
TD04H-15C 15C 1.654 2.187 57 TD04H-15C
TD04-16T 16T 1.713 2.205 60 TD04HL-16T
TD04-18T 18T
TD04-17G 17G 1.744 2.382 54 TD04-13G bored
TD04-19T 19T 1.809 2.283 63 TD04HL-19T
Mitsubishi Turbo's Information:
Flow Rates @ 15psi:
TDO4-9B-6CM2 265 CFM
TDO4-13G-5CM2 360 CFM
TEO4-13C-6CM2 360 CFM
TDO4L-13G-6CM2 360 CFM
TDO4L-15C-8.5CM2 390 CFM
MHI Turbine Wheels
TD04 1.57 1.86 71
TD04L 1.62 1.86 76
TD04H 1.74 2.04 73
TD04HL 1.80 2.05 77
TE04H 1.88 2.01 87
MHI Turbine Wheels
TD04 40.0 47.2 71
TD04L 41.1 47.2 76
TD04H 44.2 51.8 73
TD04HL 45.6 52.0 77
TE04H 47.8 51.0 87
Turbo Compressor
TD04-18T 18T
Flow Rates @ 15psi:
02-05-2012, 07:53 PM
this might be easyer to read
03-05-2012, 07:23 AM
Thanks for the info, very useful. Now for my next question, is it just the 2000-2004 impreza which has the td04l-13t? Because I have found quite a few turbo's from imprezas aged between 93 and 99 which have turbos which say td04l on the name plate, but do not give the '13t' or '13g' '15g' etc..
03-05-2012, 07:25 AM
The name plate wont contain the 13t bit, only the first part, just google the serial number on the compressor and that turbo finder page will tell you what it is.
Main thing is to make sure its a front entry one as alot of them have a 90 deg bend on the intake which is a bit of a farce.
03-05-2012, 07:32 AM
Oki doke cheers I'll do that and see what I can find.
03-05-2012, 07:42 AM
I thought the hl was meant to be silly small, but according to that info it's one of the bigger ones..? Tbf that's a lesson i should know already, don't believe anything coming from internet experts... :roll: Edited my first post accordingly lol.
03-05-2012, 08:16 AM
td04 was used from 1994 in various forms i recall, but as Darren says google the serial number to find the exact turbo profile
03-05-2012, 09:06 AM
Theres the H, the L, and the HL, the HL being the biggest turbine...
16-05-2012, 07:58 AM
what about the TD04 11G, from googling it comes off 2.5 td rangerovers and omegas with same engine.
cant find size specs like above though
16-05-2012, 04:22 PM
The "L" denotes water cooled apparently.
19-05-2012, 09:33 PM
sweeney1987 Wrote:what about the TD04 11G, from googling it comes off 2.5 td rangerovers and omegas with same engine.
It also came on the 325tds. Doesnt look much bigger than a t2/k14
26-11-2012, 04:25 PM
Damn, this is so confusing! Found a friggin 11G and thought I was onto something. I don't understand why they can't just give them different numbers if they are so varied in size. Can anyone tell which one this is? http://www.ebay.co.uk/itm/97-05-IMPREZA-...8738320%26
They all look the same to me.
26-11-2012, 06:10 PM
A td04 11g is smaller than the 13's but dunno in comparison to a t2 or similar. But why go to the trouble if changing it when you keep it similar. Either get a 13/15/16 IMO I was looking for a 16 but money has stopped me for a week or 2
26-11-2012, 06:33 PM
So do you have an opinion on the one I posted?
26-11-2012, 06:57 PM
(26-11-2012, 06:33 PM)306Puggy Wrote: [ -> ]So do you have an opinion on the one I posted?
Yeah, looks like it needs its fuel filter changing.
27-11-2012, 12:00 PM
Fuel filter? You mean oil filter? How could you tell that from the pic anyway?
27-11-2012, 12:19 PM
I meant what I said and you know it boy.
27-11-2012, 01:12 PM
get a 13t and get an ungrade kit for it
27-11-2012, 06:52 PM
Hmm, that's weird nothing comes up when I search for that model on eGay.
27-11-2012, 09:09 PM
What you searchin for?
28-11-2012, 05:54 PM
td0413t
28-11-2012, 06:33 PM
There would be an L, H, HL between and people don't usually go further than the name TD04 you'll be searching for a TD04L 13t iirc :-)
28-11-2012, 06:54 PM
you wont fin out searchin for that just try TD04 TD04L TD 04 etc
28-11-2012, 07:19 PM
That's interesting, the only 13t's seem to be new ones, the 12t's on the other hand are very popular:
http://www.ebay.co.uk/itm/VOLVO-S60-V70-...416dee0ff4
Does anyone know about the 12t's?
Also, what do you do when it doesn't show it's type like this one:
http://www.ebay.co.uk/itm/Subaru-Impreza...337e1e71ca
Good price but it doesn't say which type it is although it says it's front entry which I believe is good.
28-11-2012, 07:42 PM
ask seller for serials
