ive just put a gti6 flywheel on a 306 19 td and used a xantia 19 td sensor in top of gearbox it plugged straight in loom as jack plug the same but when started it shows flat out at 6k any ideas ?
Probally the wrong sensing system to work with yours. Why put a gti6 one on? Apart from its slightly lighter
the ring gear was f*cked i had a spare gti6 one so fitted that with a new clutch as needed both feet to press the clutch the rev counter didnt work at all before
i put a 19 td in a 1.4 once and th counter worked on the original clocks ok so dont think clocks any diffferent
