Engines
XUD Section
> Crank pulley help
Full Version:
Crank pulley help
You're currently viewing a stripped down version of our content.
View the full version
with proper formatting.
Cbray2003
30-05-2015, 09:04 AM
So don't know how but the keyway has broke on the aux pully end and needs changing but can't get it out so how do I get the crank pulley off if I lock timing and remove belt should it just slide of the shaft thanks in advance
Seb_Ryan
30-05-2015, 09:24 AM
No need to lock timing to remove crank pulley.. Bolt out of middle and lots of wiggling and prying it off
Cbray2003
30-05-2015, 10:18 AM
The aux crank pulley has snapped off and gone I need the timing crank pulley off the change the keyway
Engines
XUD Section
> Crank pulley help
