25-05-2015, 01:37 PM
I recently bought a new 306. As usual changed the cambelt/water pump immediately.
However bleeding up the coolant system, the two bleed points, the one to the right of the engine flowed coolant nice, no problem.
But the one at the bulkhead, took the screw out and no flow. So revved the engine, still no flow, but when i shut off it flows coolant, for a split second then no flow.
Any ideas what cause this? Possible air in the system? Blocked matrix?
