So will hopefully be fitting my xantia manifold soon. Bit nervous as I've heard this can be an absolute pain to do. Is there any guide or can someone tell me the process and what need removing?
Thanks guys
Top mount intercooler, turbo intake pipe , boost pipe, inlet manifold, exhaust manifold then swap gaskets and re assemble , not sure if you can retain original airfilter pipe work that runs behind the inlet manifold when you fit a xantia mani
(10-04-2015, 10:01 AM)Nath140889 Wrote: [ -> ]Top mount intercooler, turbo intake pipe , boost pipe, inlet manifold, exhaust manifold then swap gaskets and re assemble , not sure if you can retain original airfilter pipe work that runs behind the inlet manifold when you fit a xantia mani
So theoretically it's simple just space is an issue. And yeah I may have to do a new rout for the air filter, may have to run de filtered for a little bit
Pretty much is just a harder job due to lack of space tbh , can always take top engine mount off and pull the engine forwards a little with a strap around the front crossmember and to a lifting eye , would solve the issue of space, helps to remove battery and battery box too for doing the exhaust mani
Support the engine, take the left engine mount off and roll it forward. You'll need the extra room.
Cool thanks guys
big help
As said get a jack under the engine and take the cam belt side mount off and get the engine as far forward as poss. It aint to bad to do to be honest
(10-04-2015, 12:09 PM)Frosty Wrote: [ -> ]As said get a jack under the engine and take the cam belt side mount off and get the engine as far forward as poss. It aint to bad to do to be honest
Yeah hopefully it won't be the worst job ever. Gonna do it when I have a couple of days off to make sure I have enough time
