10-03-2015, 02:30 PM
Recently I have acquired one of these:
My Question is, which two pins are the coil?
There's 3 pins, numbered 1,2 and 3 (I would assume it's pin 1 and 2)
obviously my loom only has 2 wires as it's a TUD
The story. Changed my flywheel from a TUD fly (7Kg) to a TU5J4 flywheel (5.6Kg). The TUD crank sensor on the diesel only picks up one notch per rev, but the J4 fly has like 100 or something I didn't really count them.
So the tacho sits at 6k constantly. There's a hole in the back of the block looking at the back of the flywheel, designed for a crank sensor (it's a 20mm hole with an M6 threaded hole right next to it)
Basically I want to fit this sensor
