Is this important on my dturbo with a top mount intercooler? The underlay or whatever its called looks in a sorry state and was thinking of just getting rid of it and spraying under the bonnet fresh
So does anyone have any advise
Thanks
Keep it if your on tmic it helps
Little airflow is better than no airflow
4WayDiablo Wrote:Keep it if your on tmic it helps
Does it make a big difference yeah?
It makes a difference yeah. That's why its there lol :-P
I got rid of mine when I went fmic though :-)
Ah yeah i know but like i wouldn't worry too much if it made a small difference
i plan on front mounting in a few months might just leave it off
It makes a big enough difference to warrent it being there
Well without it your intercooler is just an interwarmer
Mine was mangled so I got rid. Won't hurt as long as you know how to drive an XUD.
Makes a massive difference, it ducts air from the front of the car to the intercooler and works very well! With out it the top mount is all but useless TBH
silverzx Wrote:Mine was mangled so I got rid. Won't hurt as long as you know how to drive an XUD.
Does 'knowing how to drive an XUD' make air magically go onto the cooler then?
Midnightclub Wrote:silverzx Wrote:Mine was mangled so I got rid. Won't hurt as long as you know how to drive an XUD.
Lol, not at all. But if your going to put your foot flat to the floor and rag it through 1st to 5th at every light then I can imagine it getting veeeery hot without the ducting.
I've been driving without my lining for at least 8 months now and my TMIC is never that hot when I pop the bonnet after a "rag".
If it's still there then leave it, if it isn't then don't bother replacing it if your getting a FMIC on at some point.
Simples!
Entirely depends on the boost your running though.. if your running 14psi then it won't get anywhere near as hot as 20+
Midnightclub Wrote:Entirely depends on the boost your running though.. if your running 14psi then it won't get anywhere near as hot as 20+
I'm currently running 30+psi on a top mount with no bonnet lining
Thought you had a fmic mark?!
Dan! Wrote:Thought you had a fmic mark?!
I do, it popped the hose off around the rad causing me to get properly stressed out with it as its pretty much impossible to get back on without removing most of the front of my car
Simple solution, rip out FMIC pipework and put the top mount back on
mark_airey Wrote:Simple solution, fit the FMIC properly the first time round
Edited for truth.
Think ill just run without it for awhile.. I dont abuse the car anyway
Could always direct a cold air feed to the TMIC.
mark_airey Wrote:Toxic-Jake Wrote:Could always direct a cold air feed to the TMIC.
You mean like the bonnet lining? since that is exactly what that is
Yeah but he said he wanted to get rid of the lining because of how it looks,
Yeah jakes right its in a right state tbh, its like a dog was at it for a few hours
