Full Version: Bosch throttle cable query!
Trying to use a Lucas cable on a Bosch setup but having trouble getting the arm to stay in the fully slackened position with the ability to reach 100% maximum throttle travel when the pedals fully depressed.
If the black Lucas clip is too tight it won't flex with the cable correctly and if it's too lose it just slides up the arm.
I'll add a video tomorrow.
I had that problem and just cut the springy part off the lucas cable and let the return spring on the throttle arm do the work.
Wouldn't return otherwise and pulled the throttle round too far.
