What would be causing a knock when the car is started and when you turn it off. Also happens if im drivin, let off accelerator fast and when i floor it fast. Be bottom or top engine mount maybe?
idcheck the top mount first to see if the chassis cup is cracked or broken
[attachment=15760]
Yeah was meant to do that but didn get the chance yet.
Hard fixed if it is fooked? Or just a case of goin to a lad with a welder?
weld in a plate
and cover up the shit weld with paint
[attachment=15761]
Cheers ill have a look see is it cracked.
Would of thought thats it on standard turbo, unless your lower mount is pretty destroyed...
I had a knocking in mine and decided to check out the lower mount....
Was the rubber completly gone like that or you cut it out?
Completely gone. It fell out then I took out the bolt
