23-04-2014, 09:29 AM
23-04-2014, 09:34 AM
Other than the engine capacity, I don't think they have much in common tbh! Although the 206 GTi 134 is basically just a 306 XSi engine
23-04-2014, 10:06 AM
The Gti180 engine is an EW rather than the 306 XU
I don't think the two engines have anything in common
Even down to the management systems as by the time of the 206 Peugeot had opted to use Siemens systems which are almost impossible to remap so I'm lead to believe
23-04-2014, 10:13 AM
They have LOTS in common with the later XU 16v engines, I'm guessing you also posted on the 205 forum? there's a TON of info on there about these.
Cam ladders are the same casting, smaller tappets other than 180 engine, same cam blanks, same bore centres, cranks interchange, probably a lot more but I can't be arsed to regurgitate what's posted in very good detail on the 205 forum by Sandy Brown
the 306 did not get an EW engine, nor did the 206 ever get an XU, so the xsi engines share nothing directly but the badge and similar power output.
23-04-2014, 10:19 AM
Huh, always assumed they were the same engine given the power output, can't see why pug would go to the hassle of redesigning an entire new engine and it no more powerful/better than an older design.
23-04-2014, 10:23 AM
its lighter, produces more torque, use less fuel, less emissions, lasts longer.
yeah, why did they bother?
23-04-2014, 10:30 AM
Because they are all marginal benefits? Seems like an awful lot of hassle..
23-04-2014, 10:33 AM
they didn't do it for the power....
Emissions are a massive issue for OEM's and is probably the main reason for new engines these days.
That's one of the big reasons why everything is going turbo - acheiving acceptable power outputs whilst meeting ever tightening emissions requirements.
23-04-2014, 11:16 AM
Just had a quick read on the 205 forum... Interesting stuff
23-04-2014, 11:58 AM
(23-04-2014, 10:33 AM)powerandtorque Wrote: [ -> ]Emissions are a massive issue for OEM's and is probably the main reason for new engines these days.
& better fuel economy due to increased volumetric efficiency, and as we all know fuel economy is a major selling point these days as well as environmental friendliness.
